Macgregor 26X Owner Modifications and Upgrades
Pull Cable Ballast Valve
posted 10-07-2008 by Bruce Krisko
This is a shot showing the stern layout. Note that the cable runs into the same boot with the other O.B. cables and hose.
Cable controlled ballast valve
A simple bracket is made up from a two inch section of 1 1/2 inch aluminum angle. Two holes are drilled for the cable clamp, and two for fastening it down to the transom.
Bracket attachment
Here I made a connector out of a two inch length of aluminum rod 1/2 inch dia. I drilled and taped 1/4-20 on one end to fit the valve, and #10/32 on the other end to fit the cable end. I used a lock nut on the cable end to hold it together. I filled the threads with Tef-Gel. If you dont have this you can use a good waterproof grease.
Cable connector
I used a 10 foot long cable and mounted my pull handle at the base of the steering pedistal. These parts are available at your local chandler and cost about $120.
Pull Handle
Click image for largest view
Copyright 1997-2025 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
