Macgregor 26X Owner Modifications and Upgrades
Galley Mods
posted 10-07-2008 by Dean Smith
See Galley upgrade
The first improvement I made to our 96 26X was to build a new galley insert. I wanted more organized space under the counter. I added three drawers to the aft, two shelves with a door in the middle and a door on the fore of the galley. This is all attached to a plywood face that is bolted to the inside of the molded fiberglass galley in the same way the original galley insert was attached. Most of the weight is supported on a floor that I constructed sitting on the long ballast tank tube on the bottom of the boat. Weve been using this for 5 years and it has served us well.
Click image for largest view
Copyright 1997-2025 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
