Macgregor 26c Owner Modifications and Upgrades
Galley Tip Out Drawer
posted 05-30-2010 by Doug91mac26s
When I relocated my batteries from under the sink, along with a 1,2 or both battery switch, and a volt meter, I was left with two large holes which I needed to find a solution to.
I installed a large ice chest into the countertop, that left me with a narrow space in between. So I decided to use one of those tip out kits you can get at any harware store. Theyre normally used in the kitchen in the house for tip out drawers in front of the kitchen sink.
Once I cut out the large hole I needed, I then used stainless steel bolts to attach oak wood blocks. Then I attached the hinges in the same fashion you would in the house. It worked so good, Id recommend this mod to anyone wanting a little more storage space where theres only a little room behind.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
