Macgregor 26S Owner Modifications and Upgrades
Cockpit and motorwell drain plumbing
posted 04-26-2010 by Doug91mac26s
I replaced the original clear plastic tubing that provided drainage for the cockpit and motor well. I used sched 40 PVC, and ran it as close to the walls as possible to get it up and out of the way. I also connected the discharge of my bilge pump to it. You can see the bilge pump and fish finder transducer mounted in the lowest spot.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
