Macgregor 26c Owner Modifications and Upgrades
New circuit breaker panel
posted 04-26-2010 by Doug91mac26s
I installed a new circuit breaker panel on the side of the overhead, above the galley. This is a good centrally located spot for the panel. You can see some of that blue flexible conduit, which runs to the v-berth battery compartment. I like circuit breakers as apposed to fuses. I added an analog 12 volt meter that is activated with a momentary push button switch, that will prevent any slow drain of the batteries. I relocated the dual battery switch to the head, just behind the batteries. Above the battery switch is a battery charger, that is hardwired to shore power, that red cord is actually gone now. That little white vent is there to provide ventilation for the batteries.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
