Macgregor 26c Owner Modifications and Upgrades
Rudder hoisting control line
posted 04-26-2010 by Doug91mac26s
Before I did this mod the rudder was somewhat hard to lift. I installed these Ronstan blocks on the rail making it much easier. I used two fiddle blocks, one with a v-jam. I connected them at both ends to pulpit anchors.
In the picture you can also see the tiller riser I bought from Idasailor. It keeps the tiller from dragging across the top of the laz.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
