Macgregor 26c Owner Modifications and Upgrades
Mast raising system and whisker pole stowage
posted 04-26-2010 by Doug91mac26s
I wanted to keep the mast raising system on the boat, didnt want to leave it in the tow vehicle, and I didnt like putting it below. Not only is it in the way below, but there is always a good chance of damaging the gel coat or tearing the cushions. So I now stow it on the lifeline stanchions. I simply attach both ends of the gin pole to pulpit stanchions, using snap shackles. Works pretty good, and doesnt get in the way while sailing. I use the same method to stow my whisker pole on the port side. Provides a little more safety on deck in those areas too!
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
