Macgregor 26c Owner Modifications and Upgrades
Idasailor HDPE Center Board
posted 04-26-2010 by Doug91mac26s
When I first got my boat the OEM center board was split, and the pivot hole was cracked. So I decided to replace it with a new Idasailor HDPE center board. This mod was a lot of work, because the boat had to practically be taken off the trailer. I built a wood cradle for the stern only, and left the bow over the trailer, but supported with a floor jack. I moved it just enough to be able to drop the centerboard and clear the trailer. I also had to drill a new holes of the same sizes as the old ones.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
