Macgregor 26S Owner Modifications and Upgrades
Hatch Slides
posted 04-22-2010 by Doug91mac26s
The hatch sliding fiberglass to fiberglass had worn thru the gel coat. So I installed a strip of aluminum under each angle aluminum. The aluminum strips covered the damage that was already done, making it look better. Now the hatch slides on aluminum instead of the fiberglass.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
