Click for larger view
System in action. The gin pole needs to be properly positioned so that it works properly when the mast is raised. I have found that making a mark on the jib halyard helps.
I have used this system several times and found it to be safe, dependable, and effective. Operations take place from the safety of the front of the boat (out from under the mast), and on stable ground.
