Macgregor 26D Owner Modifications and Upgrades
DaggerBoard block
posted 10-07-2008 by Lamar McDonald
I ran into this block at the on sale bin at West Marine. It is off set from center. If you need the blocks make and model, I will e-mail it to you. The block reduced the effort needed to adjust the dagger board. Also in the background, you can see the VHF coaxial disconnect, for lowering the mast.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
MacgregorOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
